shell with different thickness for different faces
UlrichHanischUlrichHanisch Member Posts: 11
edited June 2021 in Community Support
is this still not possible in shell feature? i've found some post from 2016 or so, but i thought, this feature option is an absolute minimum for all major CAD ...
  • brooke_spreenbrooke_spreen Member, Developers Posts: 115 ✭✭✭
    Do you have an example application?
    Design Engineer | Anerdgy AG
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 260 ✭✭✭
    edited June 2021
    This is not possible yet. But I use the Move face feature as a workaround. That's a way to vary the shell thickness per surface.
    Henk de Vlaam
  • UlrichHanischUlrichHanisch Member Posts: 11
    Hi Brooke, Hi Henk,
    as you can see in https://cad.onshape.com/documents/e395667907981aa9f75b5072/w/6aa7bd99473017f95b30ec83/e/65d82cd04ce3d05e361c0f64
    there are lots of extra steps to work around this Iimitation. Please roll behind „Wandung1“ and unsuppress „Wandung1“. Initially, I want to create a shell with 1mm for all global faces, but 25,5mm for all faces at the backside. This would allow to cut the resulting body by half and directly mirror the resulting body instead of adding all the extra steps. Just as an example …
    edited July 2021
    Hi @UlrichHanisch,
    I editted your part and halved the number of features (18>9).
    https://cad.onshape.com/documents/88598b1de190d61c07ddff57/w/70063ee801e69cf8664950f4/e/a9c6cac466b722fd05cacac2
    By the way, I added Move face 1 to make the rib 1 mm thick as well. So the number of features is therefore 10.
    I made the changes in Branch B1 so that you can compare workspace Main and B1 and see that there are no differences, exept the rib thickness.
    A remark about mirroring: when you add a mirror then Boolesch 2 is not necessary afterwards.
    Henk de Vlaam
