Beam featurescript butting arrows not available in all size profiles
Simon_Kozin
Member, csevp Posts: 9 ✭✭
I tried support but was directed to the forum. In the BEAM featurescript there is a nice feature that brings up arrows to allow you to change the orientation of the tubing butt joint. Unfortunately this doesn't seem to work in all shapes/sizes of tubing. I first noticed this in the 2x2x1/8 ANSI square tube (It works in the next size up). It also seems to be the case in other sizes. Is there a chance of getting somebody to look at that? Is it somehow related to the size of the beam features?
Thanks!
Thanks!
Also added ability to select curves (that are lines or arcs) for profile to follow.
