Smooth blending between two parts
roger_blainroger_blain Member Posts: 10
I have this part, where I need to need to create a smooth transition between the parts. I have tried various methods, and keep ending up with chinks missing.
I need to have the part machined, and don't want these gaps machined into the part.
Any ideas?
Here is the link to my project:
https://cad.onshape.com/documents/3a718191eadfe8f03f24048e/w/d3099d26b7a842a9d19efd48/e/90c24cd5407f7885f1371c94
  • Alex_KempenAlex_Kempen Member Posts: 252 EDU
    Here's one method, using some 3D fit splines and surface lofts to generate a smooth transition.  There's definitely better ways to do what I did, but it's hard to be more efficient since your model isn't fully constrained and has multiple broken features. If you want a more optimized solution, I would suggest fixing it up first. Otherwise, it's garbage in, garbage out, and there's only so much people will be able to do to help you.
    https://cad.onshape.com/documents/3147daba19e6fe8c5333612f/w/60f6b5f6ff2524c6d71355c8/e/b10f5c9166e46d5bf365e226
  • MichaelPascoeMichaelPascoe Member Posts: 2,412 PRO
    edited July 2021
    Here is an excellent place to learn some good modeling techniques:
    https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22All%22%5D
  • stephanos_androutsellis_theotokisstephanos_androutsellis_theotokis Member, Developers Posts: 7 PRO
    Hi Roger,
    There's a new cloud app in the Onshape App Store called Phi that specialises in freeform design. I gave this problem a try and I created a short (2 minutes) video showing how you could tackle it with Phi. I am not sure if this is exactly what you were after, I chose one approach that seemed reasonable to me but you could probably also try other ways. If you want to learn more about Phi you could have a look at the material on the product web site: https://phi3d.com/ .
    So the suggestion would be to shorten the one part as shown in the video, and then place the join that was designed in Phi in between the two blocks. Alternatively you can of course also build a freeform joint as the two parts are currently, but it may not have an ideal shape.
    I hope this may be of help,
    Stephanos
    PS. Full disclosure, I'm part of the team that created Phi, so apologies if this counts as self-promotion :-)
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
    edited July 2021
    @roger_blain
    Here’s another version
    The main thing about this way is that it uses all PLANAR surfaces. It starts with flat surfaces, near half rounds and holes. Then fillets. The primary tool was extrude. Loft was not used. So everything is easily defined
    The main surfaces lineup pretty close to what you have
    But I did use different size fillets, for a different take on your part
    https://cad.onshape.com/documents/3437b508bc3b373ccdd7bf80/w/e58357f2ae6c0a05a597991b/e/6bc27960c9f460533a926e83
    @roger_blain
    Look in Assembly for a comparison between the original part and the alternate
  • roger_blainroger_blain Member Posts: 10
    Thanks Michael, I will !
    Thanks Alex, some valuable techniques I can use !
    Thanks Steve, a useful approach!
    Hi Roger,
    Stephanos
    Well done Stephanos, this is a very interesting approach, thank you.
  • EvanReeseEvanReese Member, Mentor Posts: 2,443 ✭✭✭✭✭
    Depending on how much control you need, just using one loft might be the simplest way. Note it's not your exact shape since all of the surfaces blend and there's no hard edge.
    https://cad.onshape.com/documents/fa47616ec0d6c2dac4c481db/w/0f92d938c8cdd94cf3b3c528/e/aa9aa62bc7b2d726ed2b2c00
    edited July 2021
    @roger_blain
    I took a look at your URL again. And I noticed you were taking a PLANAR approach
    I played around with my document. Boiled it down to 20 features
    You might like the geometry on this one because it’s pretty clean and this time I used the same radius sizes that you had
    https://cad.onshape.com/documents/736ffd4b2035a8b614bb2fa0/w/c7bf6d15e884b1cd84456400/e/3104fd3ac2932bc1b800ceae
