Offset Ref plane dialog
mark_biasottimark_biasotti Member Posts: 123 ✭✭✭
What is the second value box when creating a offset plane?
  • andy_morrisandy_morris Moderator, Onshape Employees Posts: 87 image
    The second (unlabelled) input box currently sets the size of the visible extents of the plane.
    Would you want to manually control this, or have it set automatically?
    Andy Morris / Head of Product Design / Onshape, Inc.
  • mark_biasottimark_biasotti Member Posts: 123 ✭✭✭
    Hi Andy,
    I would like to do it in the workspace since that, I feel would be a lit more intuitive.
    Mark
  • matt_hardmanmatt_hardman Member Posts: 24 ✭✭
    I don't see why you'd want to control this particular option manually. Or if you do control it, why not enable dragging the corners of the plane whilst you're editing it?
  • MaggieSuMaggieSu Onshape Employees Posts: 3 image
    Just a note. If you go 'normal to' a plane, it'll zoom up to the visible extents of the plane, so setting the plane size sometimes matters.
    Maggie Su. Onshape UX Intern
