Moving/Importing multiple STL files into a single part studio
Cobalt_EchoCobalt_Echo Member Posts: 31 ✭✭
I have 3 STL files (imported as meshes/composite parts) that I would like in a single part studio so I can line them up and design a single piece off of them.  However, you don't get the option to import them into one part studio when you select multiple induvidual files.  I also tried zipping all 3 files into a zip file but got the error:  "Cage.zip was not translated. Translation is not supported for zipped STL (.stl) files."
You can see the three part studios in the bottom tabs:  Cage-Back, Cage-Middle, Cage-Front.  I would like these STL's in the same part studio.  Any information would be appreciated.
https://cad.onshape.com/documents/6d306c30df539c19a1497630/w/0223a23cd4835ddb76eda6da/e/42c51283241340910e7922cc
