Drawing a ridge around a loft
Hi.
I am drawing a simple pourer. It is oval at one end and smaller diameter round at the other. The idea is it is pushed into a hole like a hollow cork. It also has a curve along it's length.
I used a loft to create the pourer
What I want to do is to put a ridge around the circumference of this loft some way back from one end. It will be a triangular ridge as a barb to hold the pourer in the hole. I can't for the life of me work out how to get a shape to follow around the circumference of the loft, which is not perfectly round as it blends from an oval to a circle. I thought the sweep extrude was the key, but I can't constrain the triangle sketch to the surface of the loft, nor select the loft surface as the sweep path. Am I trying to do the impossible?
Mark
  • NeilCooke
    NeilCooke Posts: 6,097 image
    If the ridge is planar, create a plane and split the face using the plane - that will create a path that you can use to sweep a sketched circle.
