<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
Drawing a ridge around a loft
mark_dutton343
mark_dutton343 Member Posts: 14 ✭
Hi.
I am drawing a simple pourer. It is oval at one end and smaller diameter round at the other. The idea is it is pushed into a hole like a hollow cork. It also has a curve along it's length.
I used a loft to create the pourer
What I want to do is to put a ridge around the circumference of this loft some way back from one end. It will be a triangular ridge as a barb to hold the pourer in the hole. I can't for the life of me work out how to get a shape to follow around the circumference of the loft, which is not perfectly round as it blends from an oval to a circle. I thought the sweep extrude was the key, but I can't constrain the triangle sketch to the surface of the loft, nor select the loft surface as the sweep path. Am I trying to do the impossible?
Mark
    NeilCooke Moderator, Onshape Employees Posts: 6,115 image
    If the ridge is planar, create a plane and split the face using the plane - that will create a path that you can use to sweep a sketched circle.
