Question about mate features in Onshape
dok_man
Member Posts: 2 EDU
Hello,
new to Onshape
I created a simple 3 part model and I connect the mates via revolute
There is a base, arm 1 and arm 2
revolute 1 - the arm 1 will rotate on the base (" pedestal")
revolute 2 - and arm 2 after being connected on arm 1 will rotate around it
after I connected them when starting the revolute 1 movement the arm 2 will stay detached and wont move with arm 1, I thought that because it was connected to arm1 it (arm 2) would also stay attached
https://www.onshape.com/en/resource-center/videos/build-your-first-assembly
If you make your document public and post a link to it, that would also make it easier to troubleshoot what exactly is going wrong.
