Featurescript Custom Tables
Hugh_GoodbodyHugh_Goodbody Member Posts: 41 PRO
I have a query (definition.selParts) of solid bodies from a user input annotation, I am trying to get the properties of the parts in this query into a custom table, however the following doesnt work:
for (var part in evaluateQuery(context, definition.selparts ))
How can I access the parts in that query?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Is the query in a custom feature or are you trying to add the query into the table precondition (which is not allowed)? Tables execute after the Part Studio has regenerated so the only way to find selected parts from a custom feature is to setAttributes on those parts in the feature, then query for parts with those attributes in the table code.
  • Hugh_GoodbodyHugh_Goodbody Member Posts: 41 PRO
    Thanks for the insight Neil. Will give it a go.
