New map iteration -- INTERNAL ERROR. Trying to set type of an unbound or captured variable.
 George_Anderson
                    Member Posts: 71 ✭✭
George_Anderson
                    Member Posts: 71 ✭✭
            Using the latest Featurescript, I'm intermittently getting this message:
INTERNAL ERROR. Trying to set type of an unbound or captured variable.It always points to various places in my code where I started to use the new support for nicer map iteration:
for (var key, value in myMap){It's happening only rarely, and unpredictably, and seems to reset sometimes when refreshing the page, or switching tabs, so I don't think it is based on different part studio states (like different variable values). I'd file a bug report, but I can't seem to see any pattern, just checking if anyone has seen this.
Edit: the team is aware of it and it is a priority to fix. The current workaround is to avoid the new for loop syntax.
Feel free to use this new 2-variable for loop syntax any time you iterate through a map or an array!
