Passing a variable from Part Studio A to Part Studio B
HuguesLessardWRI
Member Posts: 14 ✭✭
Hi,
I am wondering if there was a way to pass a variable from a Part Studio to another one in the same document, at least passing only its value... I would expect that a Derive would work, but nope.
P.S. Variable can have a few different meanings in Onshape, The one I am questionning here is the one that appears as an (x) in toolbar / the feature tree.
Thanks in advance for your help,
Greetings,
Greetings,
Alex_Kempen
Member Posts: 258 EDU
My variable library FeatureScript should work pretty well for things like this, especially if you don't feel like dabbling with FeatureScript. Declare your variables in the variable library UI, then import the corresponding cube into your other part studio (using another instance of the variable library feature).
Ilya Baran's Super Derive FeatureScript also has an option to bring in variables when you use it to derive something from another part studio, so that might also work reasonably well for you.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots3
Please
For your use case, you might be able to create a workaround by adding a print layout configuration boolean to your master assembly. You could have users check it, then export their parts from the master assembly directly. Depending on how your assembly is set up, you might have to jump through some hoops with changing mate definitions and/or underlying configurations to get it to work, and the other configuration options wouldn't be hideable (since the visibility of configuration inputs can't be configured), but it might actually end up being easier for end users to use than your original solution.
I understand the logic with the boolean but don't know how to implement it. Basically the parts should be layed out flat and separated for the 'printlayout' so how can the boolean change the positions?
You gave me a solution: Double all the pieces.
One set shows the assembly in assembled form
The other shows the assembly in printlayout form with that set of pieces layed out on for 3D printing.
A boolean configuration allows the user to suppress one or the other set.
Works great. However I think its a workaround that onshape could easily implement by allowing truely global variables out of the box. ;-)
This variable library feature script can pass vars from one studio to another. It doesn't seem to work when it comes to configurations. The new global variable studio is great for disseminating values down from a global table. However I would like to have a part studio as the "flag ship" to pass values up to the global layer so others can use it. It seems it's unidirectional at the moment.
