Texture (New Custom Feature!)
MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
edited August 2021 in FeatureScript
https://cad.onshape.com/documents/46897a2d60ade8dbb04077f3/w/23398bd91a932d1432a5d204/e/201138fdd8eee8cfcd2dcac1
With Texture, you can create solid body textures by clicking a surface or face.
Use pre-loaded textures, or use your own custom texture, (See the tutorial gifs below).
This feature is a derivation of Surface Pattern by @maximilian_schommer (Onshape), Thanks Max!
Not familiar with custom features? How to add a custom feature to your toolbar
If you have any texture ideas you would like me to add to the standard library selection, feel free to comment below.
Let me know what you think! All feedback is appreciated.
How to create a custom texture:
  • Create a new part studio
  • Add configurable variables x, y, and z
  • Place the very center bottom of your part on the Top plane origin
  • Constrain the x, y, and z of your part with the configurable variables x, y, and z.
Adding custom parameters:
  • Inside your texture studio, create a configurable variable with any valid name that you like
  • When you go to use your custom texture, click the "Add configuration" button
  • Check the "Custom parameter" check box
  • Type the ID of your custom parameter exactly
RENDERCAD
«134
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 985 ✭✭✭✭✭
    Awesome script.
    Texture ideas: Diamond plate, Expanded metal, and bar grating.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    Thanks! I will add them in the next update.
    RENDERCAD
  • Brendan_LeipeltBrendan_Leipelt Member Posts: 13 PRO
    Looks awesome! Diamond plate, and various more wood plank options would be sweet. Great update either way!
    Super nice @MichaelPascoe!
    Onshape, Inc.
  • EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
    Thanks for sharing, Michael! I'm pumped about this one. Your feature announcements are getting pretty elaborate too. Skillz!
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 482 PRO
    Very cool! Can't believe this is working  :D
  • romeograhamromeograham Member, csevp Posts: 748 PRO
    Wow.
    edited August 2021
    Thanks for the feedback everyone. Here is an update for you. Keep the ideas coming!
    Update!
    https://cad.onshape.com/documents/46897a2d60ade8dbb04077f3/w/23398bd91a932d1432a5d204/e/56e5d6543ccb1f14cf1c4a46
    New Textures
    Requested by: @bryan_lagrange & @Brendan_Leipelt
    • Bar grating
    • Diamond plate
    • Expanded metal
    • Wood plank (2)
    • Wood plank (3)
    Feature Improvements
    • Quick mode: Up to 10x faster than dynamic mode. Limited configurations and surface compatibility.
    • New config menu layout (tab style): Move, Mirror, Scale, Other
    • Sort buttons for scaling. These let you sort through: Auto scale and equal x, y, z.
    • Configuration added "delete part".
    • Warning message for same studio textures: "Same studio textures have limited functionality."
    • Scale Z preset values. Some textures with real life dimensions will now default to a realistic value.
    • Same studio, part will only auto scale if you configure it to do so.
    • Add, will now add parts to each other if no merge scope is selected.
    • Code improvements, Thanks for the tips @Alex_Kempen
     Bug fixes
    • Custom texture same studio is working again. (Remember, same studio textures will not instantiate. This means that the part will be stretched instead of re-calculated. Please see the tutorial gif above on how to properly create custom textures)
    Quick mode
    Currently this mode works best for flat surfaces.
    New config menu (tab style)
    This is a tab menu, not a tab selection. This means you can go back and forth between the different tabs to change settings like a standard tab style menu.
    Sort buttons
    By default, the textures use auto scaling. If you click scale, auto scaling will be turned off and the part size will not update with your surface size unless you specify "Auto scale" with the sort button.
    RENDERCAD
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,059 PRO
    Oh that's cool
    Just did these 3 examples of expanded metal, bar grating, and diamond plate. Awesome feature script @MichaelPascoe
    Bryan Lagrange
    edited September 2021
    Working on some bead board walls today:
    RENDERCAD
    @MichaelPascoe I used your texture feature to make expanded metal for a box we are designing.
    Bryan Lagrange
    @bryan_lagrange That's legit!
    RENDERCAD
    Today's special: A reception desk with perforated brass panels.
    RENDERCAD
    That is amazing @MichaelPascoe
    Bryan Lagrange
    Love it
    WOW!
    I would like to see what you are doing with the knight.
    www.accuratepattern.com
    Nice
    nice dang work, Michael!
  • james_garrisonjames_garrison Member Posts: 2
    How do I get it to subtract properly?
    I am using a custom texture sized exactly to the face (1x1), and when I select "Subtract" it shows the geometry changes in Yellow, but nothing happens when I confirm the texture.
    I can successfully "Add" the texture to the part, but not subtract.
    @james_garrison If the subtraction fails, it will give you the preview but not subtract anything. If you share a link to your document, I will help troubleshoot it for you.
    Without seeing the document, here are a few things you could try:
    • Use the move "configuration" from within the feature to move the part so that it doesn't completely go through your targeted merge scope.
    • Scale the part down a small amount so that there are no accidental shared vertices.
    RENDERCAD
    I believe I got it to work by selecting the "Quick" function
    Is there a way to apply Textures to a cylindrical item with "Remove"?
    It just tries to take a slice off where the texture intercepts
    edited April 2022
    @james_garrison
    Yes, this should work. If you provide a link to the document, I will troubleshoot it for you.
    RENDERCAD
  • vincent_bcnvincent_bcn Member Posts: 9
    :o Crazy tool! This is incredible! thanks a loooooot!!!
  • shawn_crockershawn_crocker Member, OS Professional Posts: 949 PRO
    OMG!  This is truly amazing!  All my aluminum diamond plate rending dreams just came true!
    Glad you like it! Improvement ideas?
    RENDERCAD
  • Skr3pSkr3p Member Posts: 4
    This is Awesome @MichaelPascoe I cannot wait to try it out.  I will post a finished product once I get it implemented!
  • fnxffnxf Member, User Group Leader Posts: 146 PRO
    Is it possible to add an image as a texture?
