Something wrong with my gear assembly - can't create gear relation
will_parker589
Member Posts: 9 ✭
Hi community,
I am very new to this but so far I've managed to create some spur gears with sprockets attached and create an assembly where they are all correctly depthed and revolve around their axles.
I can't seem to create a gear relation however. I managed to do this with a youtube tutorial where I just placed simple pair of gears together and define the ratio and get a good articulation and animation (including how to align the teeth).
In this case despite the different gears being able to be revolute manipulated individually I can't seem to add anything to a gear relation dialogue.
When I create the gear relation and I need to add the two gear mates I cannot click on anything at all that selects. I can't select the gears from the left assembly parts or by clicking on them in the assembly drawing.
It just always wants me to add "Mate(s)"
Here is the Public Link:
https://cad.onshape.com/documents/3b52677f546a824ab450d8e7/w/aec6629973b7f76b479b2827/e/762f54dc4567d6b43fd45b19
Any of the gear relationships need to know which which mates you're adding a relation to.
Take a look at this approach. Let us know if you have any questions.
https://cad.onshape.com/documents/a0c723db7a0e980f8b38a116/w/9a4241dfad7ef60b63831670/e/fcb7581e94bc1ab05ca71454
