blue line that can't be hidden - it's not a sketch (all are on hide mode) and i can't select it.
asaf_chertkoffasaf_chertkoff Member Posts: 2 EDU
it's just sitting there...
i tried to roll back and find when i've created it but even if i go to the start of the action's tree it is still there.
Please, H-E-L-P!!..
    Can you make the doc public so we can take a look? If you make a copy of the doc I suspect it will go away.
  • alnisalnis Member, Developers Posts: 452 EDU
    I think I've seen this problem before. If you refresh your browser, it goes away (at least when I've had it happen to me).
  • Matt_LoMatt_Lo Member, Moderator, Onshape Employees Posts: 15
    Clearing your local browser cache or a hard refresh (shift + reload button) should clear this line.
  • Skr3pSkr3p Member Posts: 4
    This worked for me.  Thank you, I was about to go crazy!
  • justin_cooper343justin_cooper343 Member Posts: 2
    Awesome! This has been bugging me of late! So simple!
