2 lines on different planes not connecting
Amir_LahlouAmir_Lahlou Member Posts: 2 EDU
edited August 2021 in Community Support
Im trying to make a line on a different plane but use one of the existing lines on another plane for the angle but it won't snap to the other line. Im watching a youtube tutorial step by step and its working for him. Can anyone help?
  • shawn_crockershawn_crocker Member, OS Professional Posts: 920 PRO
    Usually indicates the end point of the line the other plane is not perfectly coincident with you current sketch plane
  • robert_scott_jr_robert_scott_jr_ Member Posts: 697 ✭✭✭
    Would using the USE command in a sketch on the second plane to capture the line of first sketch on the first plane, onto the second plane be useful in what you are trying to accomplish? - Scotty
  • GWS50GWS50 Member Posts: 491 PRO
    Have you tried  the Pierce command
