Kirimoto Newbie
Can someone tell me how you associate a specific cut with a tool?  When I select all the tools I need for the operation, then animate it, all It animates is one tool. It completely ignores the other tools selected.  I have a simple shape outlined with a mill then a hole in the center that I selected a drill bit for.  It ignores the drill completely.  the order of the tool use seems to have no effect either.   Also where do you define a tool offset because it is running my mill right down the center of the outline.
