Very simple FS question - dropdown for selecting from multiple variable sets
romeograhamromeograham Member, csevp Posts: 715 PRO
edited September 2021 in FeatureScript
I'm sure this is quite simple - but I'm having a hard time figuring it out on my own (extremely new to FeatureScript).
I would like to build on the strategy @Evan_Reese shows for an approach to global variables here to do the following:
I'd like to be able to pick from several standard specifications for a thing in a drop down in the UI. Then, based on the selection, different values would be assigned to my Variables.
If I select "Type 1" from the list, then the variables would be: A=1mm, B=1.5mm etc
If I select "Type 2" from the list, then the variables would be: A=2mm, B=3mm etc
Variables A, B are values from specification tables.
I understand how to create the variables and assign values etc...I imagine that I can easily create different sections in my FS that would have all the variables and their correct values. Something like this:
//Values for Type 1
v.A=1*mm;
v.B=1.5*mm;
//Values for Type 2
v.A=2*mm;
v.B=3*mm;
I don't know how to:
  1. make the dropdown show up in my UI
  2. do the if/then statement that would point Onshape to the correct values for the variables based on which item I pick from the Dropdown.
I know there are many custom FS built on this type of UI interface etc - but many are so complex (and create geometry etc) that I'm having a hard time finding code that I can emulate.
Thanks!
Romeo
