DODECAHEDRON POLYGON SOLID OR WITH A WALL THICKNESS
rod_muirhead943rod_muirhead943 Member Posts: 94 EDU
Hello.  Can someone walk me through the steps, geometry, sketches and commands to create a Dodecahedron that is about the size of a a golf ball or peewee baseball?
Thanks
    bruce_williamsbruce_williams Member, Developers Posts: 842 EDU
    Hi Rod,  see this thread.
    and if you search forum for dodecalhedron, other threads come up.  This one just seemed best with my quick search.
    www.accuratepattern.com
    Domenico_DiMareDomenico_DiMare Member, Onshape Employees Posts: 85
    Hi Rod,
    Bruce definitely suggested as good thread with a solution. There are a lot of different ways to model these kinds of geometries and its always a fun challenge to do it a different way.
    Here's the way I did it.
    I patterned a couple sketches to build up a wireframe, and enclosed the sketches to make one solid part. Then, it was just a matter of using shell to hollow the part out.
    Hope it helps!
    Thanks!! :)
