freehand moving arc segment in sketch
I've created an arc segment in sketch. Added an offset line and closed the ends. I want to move the whole thing - not resize or reshape it.
When I select all the members (2 arc segments, 2 straight lines and the center point) and try to drag/move them - the thing resizes.
How can I move it to a different place in the sketch w/o resizing it?
thank you
thank you
kev_keeg Member Posts: 9 ✭✭
just tried again with newly entered segment - still same behavior - no constraints. model is called "picker" - it is public. segment is in the upper LHS.0
The Transform Sketch tool is probably what you need:
https://cad.onshape.com/help/Content/transform-sketch.htm
