freehand moving arc segment in sketch
kev_keegkev_keeg Member Posts: 9 ✭✭
I've created an arc segment in sketch. Added an offset line and closed the ends. I want to move the whole thing - not resize or reshape it.
When I select all the members (2 arc segments, 2 straight lines and the center point) and try to drag/move them - the thing resizes.
How can I move it to a different place in the sketch w/o resizing it?
thank you
  • kev_keegkev_keeg Member Posts: 9 ✭✭
    just tried again with newly entered segment - still same behavior - no constraints. model is called "picker" - it is public. segment is in the upper LHS.
    Make sure that there aren't any constraints locking a point in position (like a coincident constraint or something like that). You should be able to move things around, but if one point is locked down, it'll scale the entities like you describe.
  • alnisalnis Member, Developers Posts: 453 EDU
    If you are referring to a model, please include its URL. That makes it easier to find.
    The Transform Sketch tool is probably what you need:
    https://cad.onshape.com/help/Content/transform-sketch.htm
    Ahh yes - of course - silly of me. Thank you!
