Unable to add dimension
michael_van_ende
Member Posts: 5 ✭
when adding a dimension to circle I encountered an error. the circle is on an created plane.
the error: Could not project the selected entities into the current sketch.
tim_hess427
Member Posts: 648 ✭✭✭✭
I think, at some point, when you're placing the dimension, Onshape thinks you're trying to reference a line, point, or edge outside of the sketch. This is probably happening after you've selected the circle and are just trying to "place" the dimension.
Try clicking once on the circle, and then moving the cursor way far out into space (so that there are no places, sketches, or bodies behind it), then clicking again to place the dimension.
It may be related to the discussion in this thread: https://forum.onshape.com/discussion/16753/dimension-tool-ignore-background-features-on-second-click#latest1 -
romeograham
Member, csevp Posts: 741 PRO
There was some recent change where Onshape (erroneously) thinks you are trying to select a second reference for the dimension. This has been bugging me for a few releases now. I don't remember when it started, but it's annoying, for sure.0
This actually worked
