DWT Importing & Text Issues.
Luke_Edwards
Member Posts: 10 ✭✭
Hello all - I have a situation that I need to try and address. I have designed a custom template for OnShape using AutoCAD.
I have created a 'custom template' - Imported the AutoCAD dwg into the template and exported with all the properties. Why is it that even though I have set the properties, (when re-imported) they are changing? My layer colours seem the same but the text that forms around the template is all messed up and not even the same font.
I can't set any default templates because of this.
Thanks for your response.
There isn't any other way of exporting or re-importing this type of file as far as I am aware.
As for the creating a template in OnShape.... Certainly not. OnShape expect you to purchase an additional tool just to edit a DWG which is ridiculous and from what I have seen it is not even close to AutoCAD when it comes to editing.
I have got to the point now where I am exporting everything out of OnShape and using AutoCAD to paper space my drawings.
