Is it possible to change the name of a measure in the configuration table?
  • S1monS1mon Member Posts: 3,298 PRO
    As far as I can tell it's not, but it should be. It should also be possible to add text to the dimensions in the sketch. I use that capability a lot in Solidworks to help explain the function of dimensions in layout sketches.
