Is it possible to change the name of a measure in the configuration table?
René_Sartorio
Member, pcbaevp Posts: 58 PRO
1
S1mon
Member Posts: 4,063 PRO
As far as I can tell it's not, but it should be. It should also be possible to add text to the dimensions in the sketch. I use that capability a lot in Solidworks to help explain the function of dimensions in layout sketches.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
2
It seems like the best option at the moment is to use variables and then their names show in the configuration table, and you can perform math on them there too: https://forum.onshape.com/discussion/comment/35410/#Comment_35410
