How do I make a part solid for 3d printing
ciro_shiaciro_shia Member Posts: 4 EDU
edited October 2021 in Community Support
I am making this model: https://cad.onshape.com/documents/97c0bff4438703fb46eab336/w/f9d9fd6b8648b1738356fc17/e/875b5b62d7deed4076b9d8c3?renderMode=0&uiState=615b591d20bf03323f3e1f55
My goal is to 3d print it using a Ender 3 V2. My problem is that when I download the top piece (Dispenser Box) as a STL, so I can slice it using Cura. The model sees the ramp inside the box as a hollow piece and does not slice it right. How do I make this whole part a single solid?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 765 ✭✭✭
    I took a look at your document early this morning and saw the ramp of your top piece as you described, hollow. Looking at it now, it seems you have found the solution. Correct? - Scotty
  • ciro_shiaciro_shia Member Posts: 4 EDU
    Yes, I saw my mistake. Thx anyway.
