How can I scale and center a img. in onshape
carlos_berdeal
Member Posts: 76 ✭✭
in General
Here I would like to try to scale this image (Sketch 14,15) so the center hole of the image lines up with the center of the part that you can see in the background. Is this possible? The edges to the left and the right of the image should line up with the edges of the part
