Duplicate feature parameter's'
Toshimichi_Oda
OS Professional Posts: 62 PRO
Error occurred, but I do not think it is not an error.
I use duplicated name of inner parameter of array, but names of two arrays are different.
It is not serious for me because I am good to change the name.
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Widgets", "Item name" : "Widget", "Item label template" : "#myParameter" }
definition.myWidgets is array;
for (var widget in definition.myWidgets)
widget.arrayItem is string;
definition.myWidgets2 is array;
for (var widget in definition.myWidgets2)
widget.arrayItem is string; // when change to "widget.arrayItem2", no error
Maybe namespace of each item of array is not exist .
This sounds like na error on our side. Thank you for pointing it out.
definitionmap).FRC Design Mentor - Team 1306 BadgerBots
Yes, this is more of a known limitation than an outright bug.
So I think it is not serious.
In precondition, I make the same two preconditions to be made to a function.
One is out of array, another is with in array-loop.
export const testCallPredicate1 = defineFeature(function(context is Context, id is Id, definition is map)
precondition
stringPredicate1(definition); //out of array
annotation { "Feature Type Name" : "testCallPredicate3" }
export const testCallPredicate3 = defineFeature(function(context is Context, id is Id, definition is map)
precondition{}
annotation { "Feature Type Name" : "testCallPredicate2" }
export const testCallPredicate2 = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Widgets", "Item name" : "Widget", "Item label template" : "#str" }
stringPredicate1(widget); // within array-loop // Error!
// stringPredicate2(widget); // no error!
predicate stringPredicate1(definition)
annotation { "Name" : "str" }
definition.str is string;
predicate stringPredicate2(widget)
widget.str is string;
for (var definition in definition.myWidgets)
stringPredicate1(definition); // no error!
