Missing Section View Option
Nath_McCNath_McC Member Posts: 136 PRO
Hi All,
Am I being stupid for has the model section view gone missing, I may have missed a. communication but the last time I used it the option was located is the view dropdown.
I have attached a pictures of my current options. Can some point me to the correct place?
Thanks
Nathan
  • wayne_sauderwayne_sauder Member, csevp Posts: 646 PRO
    @N_McCluskey
    I would try pressing ctrl+shift+r  a lot of times that clears up these little quirks that appear for reasons unknown.
    A faster way to get section view is shift+x and this would probably work even with the option not showing in the dropdown.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,980 image
    Are you running Safari? If so, please update to latest.
  • Nath_McCNath_McC Member Posts: 136 PRO
    edited October 2021
    Both seemed to work a treat. I was using Safari at the time.
    @wayne_sauder, those shortcuts are great. Thanks
