Сhanged the behavior of the function of setting the dimensions in the sketch
sergei_nesterovsergei_nesterov Member Posts: 43 ✭✭
edited October 2021 in General
After the last few updates, there was a problem setting the dimensions. In particular, when specifying the length of the segment. I select the size setting function with the cursor, select the segment to which I want to set the size. A linear dimension is attached automatically to the line.
But as soon as I press the left mouse button to confirm the size setting, the size suddenly changes to angular.
Why it happens? Previously, this behavior was not and was convenient. Of course I found a way out, I put the size indicating the end points on the segment, then the linear size is set without problems. But this is a more complicated way than just specifying the body of the line.
  • Alex_KempenAlex_Kempen Member Posts: 252 EDU
    The explanation for why this suddenly started happening is explained in my comment here:
    https://forum.onshape.com/discussion/comment/75252#Comment_75252
    The short explanation is that I noticed that it wasn't so easy to click a construction plane when an edge was clicked, which I guess was originally implemented to prevent issues like you're describing. This made creating angle dimensions to planes rather obnoxious in many cases (which is why I filed a bug report in the first place), but the implemented fix also had the unintended impact of making it much easier to dimension to planes accidentally. For now, prefer to model perfectly orthogonal to the sketch plane (keyboard shortcut: N) to avoid inadvertently selecting another plane.
  • sergei_nesterovsergei_nesterov Member Posts: 43 ✭✭
    Thanks for the explanation. Indeed, when the angle of the sketch is normalized, the problem disappears.
