Sheet Metal Model / Convert Should Recognize Fillets Automatically
S1mon
Member Posts: 3,961 PRO
If I start with a model that has fillets and convert to sheet metal, it can either select a whole surface and "convert" or use "thicken" and tangent propagation to find all the connected surfaces, but it doesn't convert those fillets to bends without me selecting each filleted "cylinder". It makes conversion take more picks than necessary. It would be nice if all the cylindrical surfaces were selected by default, and I could remove any if necessary (still trying to figure out why I would...). Coming from Solidworks, this is what I would expect.
Cylinder is a weird term here BTW. It took me a while to understand that applies to fillets. I assumed cylinder means a full 360 rotation.
You need to select the bend faces as well because those are stored in a separate list of bend edges. Sometimes I'll use delete face to remove the bends and use my own bend table to decide the metal thickness and bend radius.
It would be nice if it could automatically convert to sheet-metal intelligently. Perhaps someone could write a featurescript which allows selecting a single surface for an input, then automatically finds tangent faces, and automatically makes any touched cylindrical surfaces bend entities.. .
