Create wicker basket
nocry3
Member Posts: 30 ✭✭
I am trying to create a wicker basket as described in this YouTube tutorial (at 7:21) in onshape.
This is how far I got (Onshape Document)
but how can I now map the spiral to the wavy surface like in this picture
https://cad.onshape.com/documents/04a4f90a45ccef940224485d/w/9459af5440adebb6cc4915a5/e/0c776a774e6d5e7ae8d6eeaf
It looks like it has a ~5 second rebuild time, so I'm not sure what's making it take minutes over there. Was that before you suppressed the "Union All" feature?
At 4.29 seconds, the wicker sweep is the most intensive feature by a lot. I had a suspicion the part that's toughest to calculate is where all of the various surface patches stitch together. To get around that, I replaced the Composite Curve, which is still made of tons of segments, with a Fit Spline, which is a single clean curve. That got the sweep down to 590ms and the total time to ~2 seconds. Check it out here. Before and after images below (note the edges on the wicker are gone in the second one)
