Luke R Francis
how do i get to 300 stanless steel i forgot!
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,004 PRO
    edited October 2021
    Right click the part in 3D space, or in the parts list and select 'assign material'
    Then make sure you have the correct material library selected, Onshape's default library already has 300 SS so you may just want to use that.
    if you are using a custom material library, than you will need to update your material library to include 300 SS
