How do I breakout a part from an assembly to make changes to the part?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,007 image
    Right-click the part and select "switch to..." to take you to the Part Studio where the part was defined. If you want to edit it in relation to the assembly, right-click and select "edit in context"
