The formatting in the current Excel list looks broken. ? (Assembly Configurations)
René_Sartorio
Member, pcbaevp Posts: 58 PRO
Configuring the Assembly / Exercise: Configuring Assembly Properties
I just checked the file and it looks okay to me.
It seems the spreadsheet application you are using is not formatting the CSV file to columns. I found these steps for Excel:
- Open a new Excel sheet.
- Click the Data tab, then From Text.
- Select the CSV file that has the data clustered into one column.
- Select Delimited, then make sure the File Origin is Unicode UTF-8.
- Select Comma (this is Affinity's default list separator). ...
- Finally, click Finish.
I am not sure if you are using Excel or another spreadsheet application?
