How to ignore configuration items in Configured Assembly Properties?
I am trying to configure part numbers on some assemblies. Frequently, some of the configured values for the assembly are irrelevant to the part number.
As an example, on one assembly, a configured orientation angle sets the relative positions of movable elements. The angle doesn't affect the assembly part number, which solely depends on size. Say the assembly comes in three different sizes. I should only need three entries in the table, one for each size.
However, apparently I must list all three sizes for every possible orientation value. Otherwise, any unlisted angle will make onshape set the part number to a default value, instead of the correct part number based only on size. This gets ridiculous quickly when an irrelevant configuration value is a real number.
Isn't there some way to remove or identify certain columns to be ignored in the Configured Assembly Properties table? Or is there some other workaround?
Eleanor_Coffin Member Posts: 43 ✭✭
I filed a request about this a few months ago and this was what @TimRice said:Currently we do not support Configured properties wildcards so each variation of the configured part must be explicitly created in the Configured properties table. I added you to the improvement request to address this.4
Any updates on this? I've created a standard library configurable assembly and everything is working great, only to run into this properties issue. It seems like it completely defeats the ease to create and functionality of the configured assembly!
