Diff for Featurescript?
S1mon
Member Posts: 3,777 PRO
A while back I copied the Featurescript code for Bridging Curve and made some changes. I'd like to compare my version to the current version of the standard library code. For what it's worth, when I did this work originally Featurescript was at version 1324.0, it's now at 1618.0.
I'm sure I can just download my code and the standard code and do a diff on the command line or perhaps use some IDE or code editor (I'm on a Mac, does Xcode work?). Are there any other typical ways that Featurescript developers use to do diffs that I'm missing?
chadstoltzfus@premiercb.com
