I hope to learn and wanted a direction to start, thanks!
im_heim_he Member Posts: 4
Well im not sure where to start my learning and wanted to start on that. From basics to more advanced. Thanks!
  • Jake_DelanoJake_Delano Member, Onshape Employees Posts: 42
    The Onshape Learning Center is a great place to start, my suggestion would be to do some of the self-paced courses and move up from there. Start with the CAD Basics learning pathway and then continue to others
  • michael3424michael3424 Member Posts: 731 ✭✭✭✭
    After tipping your toe in the Learning Center a bit, find something that you want to make or design and start work on that.  Dive deeper into the Learning Center when you hit obstacles and ask questions here when you get stumped or need help with general design approaches or teminology.
