Convert a tube to sheet metal.
Hello, I would like to be able to convert a square tube to sheet metal.
This way I can see how the tube is actually laser cut, and prevent unnecessary extra processing time.
Is there a way to do this in Onshape at this moment?
I've added example pictures of a part I generated using Solidworks.
wayne_sauder Member, csevp Posts: 602 PRO
@jurjen_vellinga
Here is a sample of the approach I would use, but there are many different ways of doing it.
https://cad.onshape.com/documents/62ba33f82d66fb22d88416ae/w/a10f9c09f877a2b016a23669/e/978c87141c5820d5283c438d
2
You will have to create a small slit running the length of the tube to convert it.
Thanks this is by far the best method I have found.
