WebGL problem
jmtheberge
Member Posts: 7 ✭
Last week I updated to Catalina 10.15.7 (MacBook Pro). Before, everything worked fine. Now, I cannot open any Onshape files with any browsers (Chrome, Safari, Firefox). I did try to fix the problem without success (Chrome settings or chrome flags). Any idea what's wrong with my computer?
Additionally, what does the failure look like? Is it not logging in, not loading the documents page, infinite spinner when you try to open the model, something else?
When I try to open a file, this message appears on top of the screen : WebGL not active on your browser, and the loading spacework spinning ring keeps on turning.
It's weird that the check passes but a document doesn't load.
See https://cad.onshape.com/help/Content/webgl.htm
The last thing I can think of is to try opening Onshape in an incognito/private window making sure all extensions are disabled (including AdBlock).
If that doesn't work, I recommend reporting a bug from the documents page:
I know next to nothing about this kind of stuff, but I'll throw this out there
This is an attempt from Safari
From within Safari Preferences, make sure you have DEVELOP menu item turned on
Then once you do, go to Experimental Features and see if you have WebGL turned on
ANOTHER THING TO TRY
From Safari - CLEAR HISTORY, and then from Develop Menu - EMPTY CACHES
Sorry for the huge screen captures
I've got to try and figure out how to make these things smaller
Years ago when we use to have problems with our Mac’s, we use to reset the PRAM
Here is a recent video on that type of thing
https://m.youtube.com/watch?v=dwkZScZ3AOw
Thanks for your help. I reseted the PRAM like it showed in the video. Negative. If you can think of something else, please let me know.
i’ve got two or three more ideas but you’re gonna have to give me awhile. Just check back periodically — i’m tied up doing something so …
OK so lately the dialog boxes in Safari have been working funny. For one thing I can’t open up the pulldown menus in some of those dialog boxes
But today I happened on a temporary fix. Temporary
And here’s a GIF showing what I did
Notice that at the start of the GIF, I try to get access to that pulldown menu in the Extrude dialog, but the dialog box won’t let me
So what I did was I went down to the tab for the part studio and used —— Open in new browser tab. And in my case, as you see in this 1st GIF, doing this appears to make things work the way they should. But, in my case the fix is only temporary
So what does this have to do with your problem ?
Well, you could use that same — Open in new browser tab (command) when you first start up Onshape. Who knows, maybe if it does work, maybe your fix will stick and not be a temporary fix
Watch this 2nd GIF
So here’s what I suggest you try
Restart your computer
Then start up Safari
Clear the history
Under Develop menu, Empty Caches
Then use Safari to sign into Onshape
Then the VERY FIRST thing you should do is use — Open in new browser tab, on one of your documents, as shown in the 2nd GIF
See if you could at least open a document using this method
If this doesn’t work, I have one other thing I could think of at the moment. But let me know if this works first
These seem related...
https://discussions.apple.com/thread/253308051
https://discussions.apple.com/thread/253309962
