Why are there 8 edges in a rectangle? and How can I select 4 that define the rectangle?
monroe_weber_shirk
Member Posts: 96 EDU
I drew a rectangle in FeatureScript using skRectangle.
I solve the sketch and then debug the resulting sketch to see what is in it.
It has 8 edges. Is this because it counts the edges going in both directions?
How can I write a query that just returns the 4 edges that define the rectangle?
The broader context is that I got quite confused about every line having two edges when defining a path for a sweep made of 8 lines. I ended up simply selecting the first half of the edges to define the path, but that doesn't seem like the right approach.
