Thicken a projected curve
mark_dutton343
Member Posts: 14 ✭
I have created a sketch on one plane and then a curve on another plane, then used projected curve to bend my original shape exactly as I would like it. However, I have this lovely new projected curve, but I can't thicken it to make it a solid part.
My drawing is https://cad.onshape.com/documents/a377c966fa8a507df671bd32/w/5ca00ab76818d8f91600ae0e/e/3cec6007c1d371228cdcdd0a
Is there any way to use this like a normal sketch? I.E Thicken, shell, etc?
alnis
Member, Developers Posts: 453 EDU
You'll probably want to use fill and thicken or some other surface modeling commands. Since the curve is just a wire in 3D space, it doesn't have a face, so you first have to make one using fill before most geometry operations. https://cad.onshape.com/documents/55a503f0cf423f7a62c4df86Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0 -
mark_dutton343
Member Posts: 14 ✭
That's exactly it! Thank you. I had been playing with Fusion 360 all last week and they use a feature called patch. I was searching for this. Onshape does this so much more elegantly than Fusion 360.0
