Learning OnShape
gary_hilsongary_hilson Member Posts: 2
Question, I've been a CAD designer since 1986. Microstation, ACAD, REVIT, CATIA, Inventor, ProE, SolidEdge. Certified in SOLIDWORKS and used the program since 2008. With my background in SW, can I make a seamless transition into OnShape?
  • S1monS1mon Member Posts: 4,003 PRO
    One thing to keep in mind as you make the transition: for 80-90% of the things you know how to do in Solidworks, there’s a way to do it in Onshape. Sometimes it may seem a little different or even convoluted, but it’s usually possible. Another ~10% may require you to add FeatureScript tools (e.g. face curves, or split by silhouette- called split by isocline in Onshape). There will be a certain amount of things for which there’s no equivalent and then there will be some things that Onshape can do that just don’t exist in other tools.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,072 PRO
    20 year pro/E user here, and just completed my first year of Onshape. It was very fast to pick up. I will say though, its imperative to go through "all" the tutorials OS offers (except the couple that are for people who have never modeled in their lives). They are free, and super good, and you will hit the ground running if you do them.
  • MichaelPascoeMichaelPascoe Member Posts: 2,783 PRO
    edited December 2021
    Also, while in a studio, there is a search box at the top right of your screen. If you search for a SolidWorks tool, it should recommend the Onshape equivalent if it is available.
