How can I connect different lines in a way that my svg export shows one line?
matthias_schraner
                    Member Posts: 2 EDU
                    I work with a shaper origin. This machine uses svg files. My export shows different lines. How can I conect them to one line in the scetch mode already?
https://cad.onshape.com/documents/620dedcac83093fade282cbf/w/a6e720b114459b9d1d6c6e9d/e/c2803f2db26e2366b0364154
Under "Spant 9 drawing" you can find my problem.
Shaper Origin accepts only closed lines if I need inside or outside routing. Since my drawing exist in several pieces, it won't allow me that and I'm unable to use this router with OnShape drwings.
Thanks a lot
