Extruding the rim for the wheel lesson
a_kadish
Member Posts: 4 ✭
I'm on step 19 of the wheel rim project. I can't get the extrude to cut
the wheel rim out. What am I doing wrong? I have everything correct
according to the demo. The only thing I can think of is that the inner most
selection from which the extrude is starting from has the triangular cut
out and that is not allowing the system to generate a path. If that is the
problem, I am unable to select the inside area. If that is the problem,
where did I go wrong at the outset, since everything looked exactly as in
the demos. Thanks
It should already be public based on your account type
My document is https://cad.onshape.com/documents/bd74c7fed489482e7c158210/w/b5e0ec9e73ce73b4a3204066/e/28ba89b2596e1abf886e2274
Thanks in advance!.
Kurt.
