USE command with whole sketch
I am trying to use the "use" command to project an entire sketch onto a new sketch. Is there a way to do without selecting individual edges/parts of the sketch? Thanks.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 560 ✭✭✭
    edited December 2021
    Why not  derive the sketch ? and click inside a closed shape you can select all line's in 1 click
  • David_KirshoffDavid_Kirshoff Member Posts: 7
    solved - open new sketch, click sketch to be projected in the tree, THEN hit "use"
    You can also click and drag to draw a box and select multiple things at once.
