(Part Studio) Can you scale an imported picture on one axis only?
Cobalt_EchoCobalt_Echo Member Posts: 31 ✭✭
I would like to stretch the image on the X axis, but not the Y.  Can't seem to do it using dimensions or transform.
    @Cobalt_Echo
    As of now, not possible - you could add an improvement request.
    There are a number of improvement requests that were for scaling sketches which are solved - 12/15/21 Improvements includes scaling sketches with transform.  However, does not allow what you are asking.
    A workaround is to create surface or solid geometry from the image and then scale that with Part Transform which does allow you to scale by axis.
    www.accuratepattern.com
  • S1monS1mon Member Posts: 3,820 PRO
    Or the other work around is to use one of a million different image editing programs, assuming you have some way to know the proportions or pixel dimensions you want to use.
