Extruding left a void on an inside corner, but I need to fill it
jared_gantjared_gant Member Posts: 5
Hey y'all, CAD noob here with a basic question. I'm trying to create a stepped hole in a part (did that) but the top and bottom of the part need to be cut at an angle to fit in a recess. When I extrude that aforementioned angular cut, I'm left with a void inside the stepped hole, and I need to fill it so it is not visible from the top or bottom.
Below, you'll find a screenshot of my model as well as a picture of the real-world object I'm trying to emulate. I'm having a hard time coming up with the words for what's going on, so it's hard to search the (very well written) help manual for things that might help. Any advice is appreciated. Thanks!
    @jared_gant
    Welcome to Onshape and the Forum!
    Please share you doc for the best help.  See instructions here.
    In the meantime - It looks like you just need the wall thickness from the face of the cut.  You can add that to the sketch you made for the cut and do another add extrusion with the wall region.  See pic below.
    www.accuratepattern.com
  • jared_gantjared_gant Member Posts: 5
    I agree, that would be the easiest option, but with where this part needs to fit down in a "trough", I can't go any wider on that dimension. I can add material on the inside, almost like I would think you'd do a rib and then revolve it, but I can't quite quite figure out how to do that.
    Maybe I need to start by drawing the profile of the cutout I need and revolving that instead of trying to extrude it from the square piece. I'm not sure.
    Here's the drawing: https://cad.onshape.com/documents/f8972b73dc87f171765dbdc3/w/087252b22ed219cf2305cbae/e/90f85523695764b413a7fdcd
  • lanalana Onshape Employees Posts: 731
    Something like this  ? that can be handled by the order of operation change?
    edited December 2021
    @jared_gant
    a few possibilities:
    1) Lana's example may work for you with a fillet; perhaps larger so you get more wall thickness.
    2) You could use a revolve to add a bevel to the inside corner as you hinted at.
    3) Here is what I was suggesting to add thickness like I think your original part picture shows. Note I just did one side and rolled back to your bevel extrusion.
    That's perfect! Thanks!
