Can a linear sketch pattern be created by defining specific start and end points?
brennan_natoli
Member Posts: 17 EDU
Is it possible to create a linear pattern that calcuates the appropriate spacing between two points or lines. For example I am drawing out a pencil holder and want to create several holes that are evenly spaced on a rectangle. If I define the diameter, is there a way to select the start and end point and have the linear pattern be created? Does this make sense?
EvanReese
Member, Mentor Posts: 2,630 PRO
consider using a Curve Pattern instead, with a straight line as the curve.1 -
emagdalenaC2i
Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
You can set a calculated dimension
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0
