Joint two pipes at an angle different to 90 Degrees
bravetiger1964
Member Posts: 4 EDU
Hi Guys sorry if I cant get this properly but I have a problem with two pipes at angles different to 90 Degrees.
See below:
I tried different things including removing with a circle, using surface and thicken, using two solids and make a shell.
I did successfully the joint of two 90 degrees pipes but this one is giving me problems.
I will appreciate in advance a recommendation or guidance.
Possibly, depending on how your extruding, you can extrude the light blue up to the face of the dark blue pipe, then Extrude(remove) the middle, merging with the dark blue pipe.
I'm open for better suggestions though!
When you extrude things you probably want to use "add" instead of "new", unless this is for a weldment. For the smaller pipe, you probably want to extrude "up to next", or extrude "up to part" if you're making 3 parts. There are a million different ways to build the same thing, but I would be inclined to extrude a solid cylinder for the second pipe "up to next" (or "up to part") and then extrude/remove the hole inside the pipe "up to next", or "up to face" and pick the inside of the larger tube.
You could probably also use a boolean to remove the material from the big pipe, and then do a "replace face" to replace the end face of the tube with the face of the pipe.
