How can I fill the space between multiple fills?
Unshelled
Member Posts: 6 EDU
I'm wondering how I can fill in the space between this geometry in order to make it completely solid. Any suggestions?
Here is the document: https://cad.onshape.com/documents/eb7a7d7fe77916b7e61b78e7/w/d70f86bf5f9c8102336eff69/e/ded013de8cbae2ecd50e9b11?renderMode=0&uiState=61bceac3e5a6cd761e759f79
EvanReese
Member, Mentor Posts: 2,869 PRO
@Unshelled
The Enclose feature works, but the Fill command will also make a solid if it creates an enclosed volume. In your case it didn't because you have a lot of separate surface bodies, but if you make each fill feature "Add" as you go, it should make a solid. You'll be able to tell because you'll see "Surface 1" (or whatever) disappear from the Surfaces folder and you'll see "Part 1" appear in the Parts folder. You can also confirm with a section view (shift x)1
